Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
super c hydraulics
chev230
09-28-2013 17:31:50
67.253.154.240
I think i have a leak but cant figure out where. my resivour gets low and i have to keep adding fluid. all the hydrualic hoses and connections are good and cant find a leak anywhere. i dont use any implements with hydraulic cylinders. the only cylinder is the one to raise and lower the fast hitch wich does not leak or seep oil. i need help to find the cause of why my resivour getting low.
[Reply]   [No Email]
dwag
09-28-2013 20:33:31
216.24.118.72
 Re: super c hydraulics in reply to chev230, 09-28-2013 17:31:50
Simplest way would be to change alt to a 1 wire hookup by replacing voltage regulator.
[Reply]  [No Email]
IH fan
09-28-2013 21:55:50
174.70.169.139
 Re: super c hydraulics in reply to dwag, 09-28-2013 20:33:31
Huh???????
[Reply]  [No Email]
GRAPE-DRANK
09-28-2013 22:02:07
96.253.107.73
 Re: super c hydraulics in reply to IH fan, 09-28-2013 21:55:50
I think he posted in the wrong thread......
Yep, yep, and yep. Same thing happened to me. I hear you can rebuild it. I just bought a new pump, put it on the tractor Thursday. Problem solved. I was shocked comparing the 2 pumps. The new pump has super tight tolerances. I could barely spin it by hand. Changed out the drive gear, hooked it up and worked very well. I can't get over how responsive the hydraulics are now. Pressure is outstanding.
I went the expensive route.
[Reply]  [No Email]
El Toro
09-28-2013 17:41:29
96.244.7.206
Brian covered your leak problem. Hal
[Reply]  [No Email]
Brian Schmidt
09-28-2013 17:35:29
69.66.237.150
Check the engine oil level. It is probably rising. The hydraulic pump will leak into the crankcase. The pump can be removed and easily rebuilt with a speedy sleeve on the shaft and a new seal on the drive shaft. The dealer can help you or you can go to a bearing supply house with the pump disassembled.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
