FYI = Clutch / Pressure Plate Adjustment
FBH44
Just FYI, I was emailed a copy of IH Service Manual GSS-1095, titled "Clutch Adjustment", by the good CaseIH dealer in Lamar MO. This manual states that the clearance between the pressure plate fingers and the throwout bearing should be adjusted to 3/16" for the SA, SC, H, and M tractors. The Cub should be adjusted to 1/8" clearance.
I get the impression there are other clutch adjustment manuals you might be able to get online. Might help.
