rebuilding the front end. I was able to weld a bead on the inside of the front bearing cup. heating it up - it fell right out. Now on the back side, I did the same, but cup wont come out due to what I believe is the wear sleeve?
my question is can I weld a bead on the wear sleeve and it fall out hopefully?
I did put a couple small bottle touches to heat it, but it would not move.
Any ideas?
NOTE: thanks to Ken Updike for the weld trick.
Any ideas?
