farmall m radiator cone washers
butch49
I found one cone washer when I took off an old radiator on my m and am putting a new radiator on what kind of washers did farmall use for the top and bottom of the springs under the frame
I don't know of any cone washers on rad mount at bottom of M radiator, the order that I recall was 2 studs screwed into bottom rad tank, 2 tire carcass pads to sit on lower bolster, a washer & nut underneath against spring from bottom side of bolster on each stud.
