I have a 16.5 HP vertical shaft Tecumseh engine on my Lawnmower. It has had problem with carb. I tried to clean and it did not help. I installed a new carb and it ran fine . Cut it off and started several times; ran like new. I put everything back together and started it and it started pulling oil thru carb from crankcase vent tube. I removed the tube from the carb and it is splashing out the rubber tube.
What should I look for . I am puzzled what could have occurred? Any thoughts will be appreciated.
Thanks, Randy
Thanks, Randy
