TractorLinks.com
Show Parts for Model:
Re: 1958 IH Utility Bac khoe Runs (Barely) then quits
rustred
09-06-2013 08:48:34
compression is good.??? what IS the actual compression readings? these engines are a cold blooded thing and till warmed up kid of like to stall. but they will start with just a push of the button. has to be something plugged in the carb. what does "went through the carb" mean? was it taken apart and soaked in carb cleaner, and all passages blown out with air? like pretty vague info to go on. also any old tractor i aquire gets the valves set to spec also, have found many with little clearance or else lots. that is part of a tune up. then i check compression and record readings. then you know if you can smile or use your second language .also the main jet on carb should be 4-5 turns out. maybe its just a carb adjustment?
