TractorLinks.com
Show Parts for Model:
Re: rear tractor tire repair ????
SDE
09-05-2013 15:05:02
The tire is old, but looks new . The cut is about two inches long and it is not as high as the rim or as low down on the tire asto be by the lugs. I need to get into town to the Bloodmobile, so i do not have time to post a picture. I need to make my camera a habit.
Thank you
SDE
old
09-05-2013 15:52:30
 Re: rear tractor tire repair ???? in reply to SDE, 09-05-2013 15:05:02
I have done a good many repairs like that. You need a good tire boot that is twice as big as the cut. Then you need to clean and rough up the area and then put in a tire patch glue. Let it dry then lay the boot on making sure you have it sitting right it should have on it how it should sit. Then what I do is air up the tube inside the tire so it holds the boot in place real good and let it sit over night that way. Last 2 I did you can almost not see where the cut is
rustred
09-05-2013 15:12:36
so that must kinda put it in the centre side wall. kind of a bad spot due to the flexing. but use a patch that just covers the cut. then use a big one over top of that. should get you by for some time, long as not doing heavy pulling. keep the tire aired up to max will help.
504-1
09-05-2013 20:29:23
 Re: rear tractor tire repair ???? in reply to rustred, 09-05-2013 15:12:36
I patched a cut that the tire dealer would not even do a section repair on it. Buff the inside good and spend a little more and buy a can of tire cleaner(for tire repair) I used a boot abought 12 square, and it has been on a working tractor for three years(sidewall cut)
