TractorLinks.com
Show Parts for Model:
Re: rear tractor tire repair ????
rustred
09-05-2013 14:50:19
just make damm sure the tire is worth that patch. nothing guaranteed on this tire. how big is the cut? picture? it all boils down to the size of cut and position of it.
SDE
09-05-2013 15:05:02
 Re: rear tractor tire repair ???? in reply to rustred, 09-05-2013 14:50:19
The tire is old, but looks new . The cut is about two inches long and it is not as high as the rim or as low down on the tire asto be by the lugs. I need to get into town to the Bloodmobile, so i do not have time to post a picture. I need to make my camera a habit.
Thank you
SDE
old
09-05-2013 15:52:30
 Re: rear tractor tire repair ???? in reply to SDE, 09-05-2013 15:05:02
I have done a good many repairs like that. You need a good tire boot that is twice as big as the cut. Then you need to clean and rough up the area and then put in a tire patch glue. Let it dry then lay the boot on making sure you have it sitting right it should have on it how it should sit. Then what I do is air up the tube inside the tire so it holds the boot in place real good and let it sit over night that way. Last 2 I did you can almost not see where the cut is
rustred
09-05-2013 15:12:36
so that must kinda put it in the centre side wall. kind of a bad spot due to the flexing. but use a patch that just covers the cut. then use a big one over top of that. should get you by for some time, long as not doing heavy pulling. keep the tire aired up to max will help.
504-1
09-05-2013 20:29:23
 Re: rear tractor tire repair ???? in reply to rustred, 09-05-2013 15:12:36
I patched a cut that the tire dealer would not even do a section repair on it. Buff the inside good and spend a little more and buy a can of tire cleaner(for tire repair) I used a boot abought 12 square, and it has been on a working tractor for three years(sidewall cut)
