Lynn Patrick
I am new to this board, usually hang around the Ford sites.
I recently bought a 1971 Cub Cadet 154. It needs tuned, but I don't want to just put the same # plugs back, in case some PO has put in the wrong ones. Can someone tell me the correct plug # along w/plug & point gap setting? On the older Fords I go one heat range hotter plug than original. Is that advisable on this engine? Also, is 10W30 advisable or 15W40?
Thanks!
Lynn
Thanks!
Lynn
