Russell Dewsnup
On my M if I let it set for more than a couple of days without starting it. I have to remove the starter from the block and put it back in in order for it to turn the engine over. I have looked a the teeth on the fly wheel and the bendix drive, all look good.I am miffed as to what it is doing. I can turn the engine over with the crank and it will make no difference. Once I take it out and put it back in it will turn the engine over and start. I have tried running a separate ground to no avail. I am open to any and all suggestions.
Thanks in advance for any help.
