TractorLinks.com
Show Parts for Model:
Re: belly pump plumbing
IH fan
09-03-2013 14:05:21
If you stay with pipe threaded fittings, as DeltaRed says, use Teflon tape sealant like he suggests. If you go from pipe to JIC fittings on your hoses, only the pipe end needs sealant. I believe the H/M are only capable of about 800-900 psi, so any hydraulic hose should work... don't need multi-layers of wire until you get to somewhat larger size hose than you need.
