Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 656 d not starting
Dieseltech
08-22-2013 19:11:11
Just loostening the line nuts at the injector is not enough, best to tap the line and make sure the line sleeve pops loose. The SV7922 line sleeves wedge in tight each time the line nut is drawn down. I like to remove all glow plugs to allow engine to crank easier. When fuel is at each injector, then tighten the line nuts. Crank again until you see air/fuel mist at each glow plug port, install plugs and start engine after heating plugs. If you never get fuel you may have metering valve and/or stuck plungers. Or worse, a seized head/rotor assembly.
