TractorLinks.com
Show Parts for Model:
Re: Plumbing starter tank and sediment bowl
RustyFarmall
08-22-2013 13:59:20
The early tractors had the sediment bowl installed on the starting tank. The later tractors (most common) had the sediment bowl mounted under the main tank. I wonder if maybe the aftermarket manufacturer didn"t realize there is a difference and is selling those dual inlet sediment bowls as a "one size fits all" thing?
Have you tried mounting the bowl to the starting tank? Of course, that configuration would require 2 completely different fuel lines as well.
Yooper Farmall
08-22-2013 14:16:56
 Re: Plumbing starter tank and sediment bowl in reply to RustyFarmall, 08-22-2013 13:59:20
Hello Rusty,
Yes I did try fitting the dual fuel sediment bowl to the starting tank as well, but same problem, lines would come from general front and right.
Looks like all the site I've found only sell lines for the 12/3 bowl, but then only sell the 9/3 bowl.
I'll get a 90 degree elbow and that should solve the problem. It'll be hidden behind the battery box, so shouldn't look too hokey!
Diagram shows a shut-off valve T on the starting tank, incidentally, I called CASE-IH and they do still have that T for sale, for $150+ !
Decided I'll put the dual-fuel bowl under the big tank, and use the single outlet bowl under the starter tank. That single bowl would have been destined for the trash and is free.
