350 Distributor Help Update
I pulled the distributor again and scaped off that last little bit of paint and found the "O" faintly stamped in front of the D7. I also discoverd the dwell was off so I rest the point gap. The timing is now correct and according to my timing light it will advance a full 22 degrees. Another thing that was confusing me was the miss I was having at full rpm. I adjusted the main jet to richen it up a little and now it runs like a top.
Thanks for the input.
You are welcome. Thanks for the update, we often are left hanging with no solution selected from the options given. Jim
