Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall 460 wiring
Janicholson
08-19-2013 10:16:31
THe issue is likely to be grounded lead to the movable point. Often at the pass through on the side of the distributor. I will bet that the point side of the coil shows no voltage when a piece of plastic is put between the points and the key is turned on. If so the point spring and conductor, the condenser lead, or the small bolt is touching ground at the distributor case of point mounting plate. Jim
tjoeerry
08-20-2013 05:15:23
 Re: Farmall 460 wiring in reply to Janicholson, 08-19-2013 10:16:31
Thank you Jim I will check that out too.
Copyright © 1997-2015 Yesterday's Tractor Co.
