TractorLinks.com
Show Parts for Model:
Re: 450 gas valve stem seals
D Slater
08-19-2013 08:03:15
Some puts umbrella sells like was on some fords but I don't have a number. Perfect circle made some with a Teflon wiper but the valve guides needed cut down to install them. May be the same as the sealed power you mention. Trying this set on a 350 head that will install without machining. Has a metal jacket with rubber inside that will fit without turning the guide OD down. Just measured the guide OD and looked up applications that listed stem size and ID of the big end. Then made sure they would clear the springs. Was afraid they may be to much oil control, but so far so good. Haven't used long term enough to determine the end result though. Guides were still in spec but on the edge of the high side.
Janicholson
08-19-2013 10:20:32
 Re: 450 gas valve stem seals in reply to D Slater, 08-19-2013 08:03:15
Best solution and looks great. New cars are so equipped and lasting 3 times as long as before, Jim
Bob
08-19-2013 08:57:28
Thanks. I have a catalog listing them by dimension at the shop, nearly 30 miles away, and am hoping someone has a number so I can get some ordered before I get up to the shop.
