Tom Fleming
Guys, I got a 1928 Little Genius plow with the Regular I bought from an estate 2 years ago. The plow was purchased with the tractor. On steel wheels. I am thinking about starting the restoration. The plow bottoms are bolted on with square head bolts instead of the normal flush, flathead plow bolts. I have seen a few old photo's of other Little genius plows of the same vintage with the same bolts on them.
Are the square head bolts correct? Is this a farmer "field fix"? While they won't add significant drag to the bottoms, they surely are not flush either. I haven't gotten around to removing one to see if they have the recessed square to hold a regular plow bolt or not.
Thought I would post and ask.
