Anonymous-0
Working on final steps to put a 1979 Cub to work. While I have the IH50 shop manual, it is not very clear how to check the fluid level for the trans. and diff. OR what type of gear fluid to use.
Questions - how do I check fluid level? Is this fluid for both the tran. and diff.?? What type of fluid (gear oil) should I use?
Thank you in advance for you assistance. David
