TractorLinks.com
Show Parts for Model:
Re: 986 pto shaft
Larry B. 1486
08-11-2013 19:31:45
I have never broke a shaft on the tractor but have heard of it happing. Around my area, exchange units run around $500.00 for dual shafts. Not sure about rebuild cost doing it yourself. 15 ft is not too much for a 986. I used a 15ft for years behind a 806 and 856 about the same size as your 986. Does you your PTO shaft on the bushog have any wobble in it that might have caused the tractor shaft to break? The PTO units are the same from a 706 thru a 1486.
urbancase
08-11-2013 20:24:47
 Re: 986 pto shaft in reply to Larry B. 1486, 08-11-2013 19:31:45
yes i do need to replace some items on the driveline of the brushog also, were the shaft cracked it looks like it had a crack for a while, i just checked on replament shafts and between $250 amd 350 depending were you get it. thanks for the reply.
