I've read a bunch of tie-down regs and everything I've read agrees. If there is a requirement to use chains and binders somebody point us to any state's DOT regs that say so.I was to the under standing that you could usr EITHER chains/binders OR Webbed ratchet straps as long as there were the correct amount used and they met the correct weight rating of what is being tied down????
(which makes sense)The use of synthetic webbing to secure flattened or crushed vehicles is prohibited.
....and for vehicles according to the US DOT.straps are for hauling hay and lumber.
(quoted from post at 10:35:03 08/09/13) straps are for hauling hay and lumber.
(quoted from post at 14:58:16 08/09/13) To ADD to Pete's statement :
Mixing straps and chains together could be an issue. The chains and the straps will always be of a different load rating from each other no matter HOW you size them.
ONE of the two will ALWAYS be the "weakest link".
(quoted from post at 08:31:56 08/09/13)
I loaded SH last year for a ride and used 3 -2" straps and used a 3/8" chain and binder. Since then I have been told that straps are not legal.
IS it correct that only chains and binders can be used?
(quoted from post at 18:39:59 08/11/13) Well,I have used BOTH chains and straps and if
either are in bad shape,you are just screwing
yourself! Regardless what DOT says.
If your binders are sized correctly and are in good
shape, I DO NOT see how the would be a weak spot. I
have seen some crapily made binders,but they were to
too small anyway to be using for ANY kind of tie
down purposes.
