Michael Sheik
'67 424 with a international 1501 loader. Loader is currently hooked into hydraulic pump run off front of crankshaft with it's own reservoir all mounted out front of radiator. The pump is not the one that originally came with loader as that one went bad and dad put another on years ago. It has way too much gpm output and operates the loader too fast thus not enough lifting power. I am wanting to put it back close to original speed and power but can't come up with any figures from caseIH parts man. Was wandering if I could plumb the loader into the tractor hydraulics and do away with the pump and reservoir out front or should I stay like it is. If I stay like it is, does anyone have any literature that specifies pump output gpm/pressure or even better yet a pump brand and # to use.
