TractorLinks.com
Show Parts for Model:
Re: Rats! PTO quit on 856
caterpillar guy
07-31-2013 10:02:40
check oil, then check pressure down under the piviot for the valve through the hole in the bracket that holds the linkage there is a plug you will need a special fitting from your friendly dealer for about 30 dollars then screw in gauge. It should read about 160-240 depending on the tractor model. I would set it at the 200-240 figure. The valve will come out the bottom without pulling the unit. There is a plug there you will need to either face it down hill or drain the oil though.
