Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: head gasket sealers
mike1972chev
07-31-2013 03:47:15
I guess I will "chime in" here also.
Plain bare steel gasket OR any composite gasket,steel,paper combo WITH OUT sealer on it(like an old McCord or Victor.) K&W Copper coat both sides or the aluminum paint trick.
Fel Pro Perma torq blue gaskets, NOTHING .
ULTRA high compression race/drag engines WITH water jackets: Copper head gasket with o ring and wire in the block, receiver groove cut in the head. Then, "Yama bond" sealer(Yamaha engine sealer) around EVERY water port in head and block. Then get it together QUICKLY and torque in 3 stages.
NO water jackets in block/heads,skip the Yamabond stuff.
I dont like doing this one. :(
Just thought I would "add" that last one for fun! ;)
mike1972chev
07-31-2013 03:56:01
 Re: head gasket sealers in reply to mike1972chev, 07-31-2013 03:47:15
BTW,the coppercoat/aluminum paint has NOTHING,nada,ZERO, to do with sealing the cylinders ,(Thats totally the job of the wire rings in the gasket)
The sealers are used to seal up the water and oil ports from the block to the head.
(Probably stating the obvious, But............)
