Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: ignition problems IH 450 12 volt
07-30-2013 21:17:57
Are you verifying with a tester of some kind that there is no voltage to the starter? My 12 volt 400 farmall system acted just as you described it would only click with a brand new optima battery installed until I loosened the starter bolts and I discovered that the starter was stuck against the flywheel. Common farmall problem. If it is stuck once you loosen the bolts enough you should hear a snap as the starter gear retracts. Fixed mine.
