TractorLinks.com
Show Parts for Model:
Re: ignition problems IH 450 12 volt
Janicholson
07-30-2013 20:29:24
Use a jumper cable as a connection paralleling the lead to the starter switch. If it then starts, the issue is the cable. Many times the cable is internally corroded. It should also be possible to find a hot connection or warm wire if a connection is bad.
Hook a test light to the connection going into the side of the starter. If it lights when the key is turned to start, the issue might be in the starter.
Jim
tom levandoski
07-31-2013 13:43:43
 Re: ignition problems IH 450 12 volt in reply to Janicholson, 07-30-2013 20:29:24
Thanks all you guys I am working on all the info you sent nothing definite yet will let you know if I find anything!!
