Kevin NE Ohio
New User
Hello,
I have a 656 I removed the center section to put new seals in the TA. I reinstalled everything and now for some reason the clutch will not release. It is like the fingers are too far from the throw out bearing. I did not change anything with the clutch I lined everything up properly. Also for some reason it will not go into neutral even though the 3 shifter linkages appear to be into neutral. I am needing some help bad!!
Thank you
Thank you
