Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1466 aux hyd valve under seat???
pete 23
07-28-2013 19:49:44
Yes, you can take the spool out from rear. The pipe that the large hex cap screws into must come loose though and come along with spool. Kind of hard to explain how to repair it from here though. Lots of guys would bring the spool into the shop and I would repair them and give instructions on how to put back in as you can mess it up doing that also.
TedinNE
07-28-2013 20:18:45
 Re: 1466 aux hyd valve under seat??? in reply to pete 23, 07-28-2013 19:49:44
If it is the outside lever your problem is most likely the roll pin in the lever that pulls the valve spool.Pull front the cover off below the seat. Watch the linkage when you move the lever forword you will see what I mean. There is also a stop bolt to limit forward movement of the lever. Make sure it has not been turned in to far.
