Anonymous-0
I have a 54SH. Was running it the other day and it sputtered and died. I haven't been able to start since. I changed the points and nothing. I thought the coil might be toast and tried another and still nothing. How can you tell if the coil is bad? I have 12 volts on both sides of small terminal. Another thing is that my lights don't work now and when I pull out the kill switch my gauge does not show a discharge. Can anyone give me some ideas on what to check? Also, it is a 12 volt system with an original coil. Do I need a resistor in front of the coil or a voltage reducing device? Thanks for your help
