Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Super H
Dr.EVIL
07-28-2013 18:35:40
Your lights are fused with a 10A glass tube style fuse next to the push/pull ignition switch below the amp gauge, turn the cover 1/4 turn and it pops out with the fuse. Buy a box of five replacements at an auto parts store.
You should run a ballast resistor in the wire that runs from the ignition switch to the coil, a part from a '60's vintage Chrysler works well.
You don't say how old your ignition condenser is/was, but it sure sounds like that's your problem. All the new condensers are made off-shore and they're quality stinks. They used to easily last 250-400 hours of run time, now you're lucky to get 100-150 hrs.
DV
07-28-2013 18:42:00
 Re: Super H in reply to Dr.EVIL, 07-28-2013 18:35:40
The fuse for the lights is good. I did also put a different condenser out of an old tractor. Not sure if it is good or not. Do you just use a resistor even though it was 6 volt before? Is there a difference from 6 to 12 volt coils?
