Which engine does my 560 have ??
jerrodlk, L.H. side of engine. Immediately Left of the oil sending unit (little round thing has an electrical wire running to it!,,, about the size of a silver dollar round) AND Immediately Right of the the Oli Filter Base, at the top edge of the L.H. frame rail is a flat place on the Block, D282 is stamped there and the Tractor Serial # too! (if the motor is still original!) Middle of the Block basically!
that flat spot may be covered with grease, and oil and yrs of dirt So you may need a scraper, wire brush, and a good rag and a can electrical cleaner, or ether! Hope this helps1
Later,
John A.
