Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1086
The tractor vet
07-27-2013 06:52:09
First off does a red lite come on in the dash when you push down the clutch with the engine running ????????? if not fix the lite in the dash . Next change the hyd. filter . When it stops moving do you still have steering and brakes ???? does the three point still work????? Do you hear any unusual sounds , sometimes hard to hear in the cab. Drop the cover plate under the clutch housing and see if ya have any extra pieces and parts fall out.Check cab mounts and clutch adjustment dump valve and trans brake adjustments , if you do not know what your doing there then get someone that does. Also check hyd oil level .
