Crazy Horse
What is the capacity of the tranny/differential on a 1945 Farmall A? I assume they are one and the same for using the same oil.
Also need the capacity for the rear PTO unit as well as the belt pulley unit, once again if they are separate and by themselves.
Last one is the capacity of each of the rear axle bull gear oil pans. And with these, does the oil level go up to the fill plug or is it at or below the pan's gasket level?
