Will an IH 2000 loader fit onto a 350 RC
Brendon-KS
Location
Goessel, KS
A neighbor of mine has a 2000 IH loader that is currently mounted on a 460 that he is willing to sell. Would this mount up on my 350 row crop wide front? Are the frames of these two tractors the same width? I realize that brackets can be swapped but am curious how close it would be as is. Thanks.
IH made them to fit a 350. May need different brackets or move the ones on it to a different setting. Frame rails on a 460 RC are 2 inches or so wider apart than the 350 RC.
2000 loader on a F-460 will not bolt directly on to a F-350 "as is". It will require modifications to the subframe rear axle mounting method and acquiring of proper front mounting brackets. Subframe from a loader mounted on a 460 tractor may require shortening to get it proper length for a 350 tractor . A good welder with design engineering skills could make modifications to the rear subframe and could build front brackets that would work satisfactorily. Compare illustrations 11A (460 tractor) and 11E (350 tractor) in first scan for rear axle mounts. In second scan , compare Illust. 10C (460 tractor) with Illust. 10E (350 tractor) front mount brackets.
Hope this helps.
Hmm, rear axle mounting should work, as the rear axle housings are practically identical from the 350 to the 460.
Main issue is the 460 is wider and longer in front. You can use spacers and longer bolts on the 350.
