Coolant guage - where does it plug in?
Jim Isler
I have a 1947 B (FABM213239G) that I found without any guages. There is a "heat indicator" in the parts manual, but I cannot locate a place to screw it into the block. Were these guages optional? Is the heat indicator for a hydraulic pump? didn"t know if B came with hydralics
Optional.
First pic is stock location, second pic would be a more accurate, but not "correct" installation.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/IH/B_IH_TEMP1_zps60b436d8.jpg">
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/IH/B_IH_TEMP2_zps4c842f8c.jpg">
Bob has the answer. Heat guages were an option most were used when it came with shutters for keeping engine warm in winter and for starting on gasoline then warming up enough for the distilate fuel then avaliable.
