boomer22
sorry i know this must been asked a lot and I have searched, can't seem to confirm if the M hoop part draw bar (the whole frame and all, without the swinging draw bar part) will fit on the h?
guess I'm gonna have to try it. mine busted in the middle. it was previously welded lasted a long time too.
All of that will usually bolt to a H. Only thing is the square tubes on most M that go to the front of the axle won't go in the axle slots. If you have tubes like started being used on the 400 series they are more rounded and will squeeze in the axle slots most times.
V it out good and reweld it. Then add a bar about a 1/2-3/4 thick under it you will be fine. All ours have had the swinging drawbar reinforced and the drawbar it's self done too. Both the H and MD
