10-20 Mcormick hubs
johns
Hey guys I"m trying to find a 6 bolt hub that fits my 10-20 front axle so I can run 7.5x18 pressed steel front wheels and tires. Any other models that have the same axle stub size as a
10-20?
(quoted from post at 18:54:28 07/08/13) Will the 6-bolt F30 hubs fit, Mike?
I would say yes since you can put 30 wheels on a 20 and vice-versa
im probably wrong though...lmao :lol:
I just looked in my parts books and compared wheel bearing part numbers between the 10-20, F30 and F20. I come up with part # 13206DA for the inner bearing and 13200D for the outer bearing. These same numbers are listed in all 3 parts books as being for those bearings.
The next step would be to physically try to fit a 6-bolt F30 hub to a 10-20 spindle and see if it will actually work.
Thanks for the help Kirk. I tried looking up parts on the CASEIH website and sure enough no parts books for the 10-20 or F series.
