TractorLinks.com
Show Parts for Model:
Re: Farmall b oil pressure
old
07-07-2013 21:33:17
Thank you
georgeky
07-07-2013 23:39:57
 Re: Farmall b oil pressure in reply to old, 07-07-2013 21:33:17
no problem Rich. most folks make way to big a deal about low oil pressure readings. I always hear fellers hollering about having 60 or 70PSI pressure. BS. 70 pounds would blow every seal in an old engine in short order. I am happy with my 4 or 5 pounds. my old tractor just keeps going and going. haven't even had new rings in since the late 60s.I decided long ago that 4 or5 psi was plenty.may not be enough for a green tractor but red ones just keep going. We are working the snot out of 5 c's and Superc's right now trying to keep all this baccer plowed. we have had waay to much rain here and in danger of loosing a big chunk of our crop. I guess a third of it scalded down today.tobacco is a dry season crop. I will take a dry year anytime over a wet one. I can pump water on if needed but can't take it off.
old
07-08-2013 07:31:12
 Re: Farmall b oil pressure in reply to georgeky, 07-07-2013 23:39:57
Know what you mean. I use my BA which is half B and half A to mow hay with and the oil pressure runs when hot just above the red on the IH gauge. I also have been using a IH 340 to rake hay this year and it runs around 10psi. I also have a few old A/C tractors and those also run with low oil pressure in the 5-10 psi range all day long for decades. Now my Oliver Super 88 it runs a good bit higher
