TractorLinks.com
Show Parts for Model:
Re: Welding Up M Drawbar
Janicholson
07-07-2013 20:36:10
Make the bushing a press fit at about .002" interference. Press it in then weld it with about 150 amps of E-6011 (no grooves). Grind it flat and there you are. You are not trying to hold pressure with the weld, so grooving is not needed. Jim
gene bender
07-07-2013 21:08:56
 Re: Welding Up M Drawbar in reply to Janicholson, 07-07-2013 20:36:10
Make a new piece from rite under the roller between the holes. Drill the desired holes round the end and then v-grove other end and weld it up. Splice will be under the fixed part. You wont be able to get a bushing to fit the worn hole and in that area drawbar is worn thin. It will look like a new one when done.
