Farmall H govenor
ellson
I"m working on a 39 H and idles great but when I open the throttle it reaves up for a second and then goes back to idle I"ve adjusted the govenor and carburetor linkage Could the spring in the governor be weak and need replacement?
Internal components in the gov. are probably worn. The link from the tube to the carb is tricky, and could be bent enough to jump out of the slot. If the carb to tube connect is for sure, going inside is a must. Jim
I've been inside the governor and adjusted the stops and shortened the rod between governor and carb. If the governor spring was weak would it cause the engine to run too slow or too fast?
