Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: IH 684 Hydraulics
07-01-2013 08:24:54
often folks use the wrong hydraulic fluid in these and here is what happens. these tractors are equipped with wet type disc brakes which require oil with a brak additive in to preserve the disc. if plain hydraulic oil has been in that tractor it will make the disc deteriorate and clog the filter causing many of the symptoms you described. I would drain it,refill with new Hytran and replace filter. may cure your problem
07-02-2013 05:05:28
 Re: IH 684 Hydraulics in reply to georgeky, 07-01-2013 08:24:54
Thanks for the advice. I thought about using Morris Super Universal 10W/30 as it meets the requirements of MS1209 (according to the data sheet) and is avilable locally.
