Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: F-20 flywheel installation update
Old-F20
07-01-2013 07:36:18
so your leaving a known cracked flywheel in there with part of a key??? seriously??
remind me to never be around your tractor when its running
RedJoe
07-01-2013 09:38:52
 Re: F-20 flywheel installation update in reply to Old-F20, 07-01-2013 07:36:18
Have to second this comment. This is not a very smart move. There is not a big demand for f-20 flywheels so i'm sure you could pick one up cheap. I'm a big fan of the f series tractor's and have redone a few. How could you leave a cracked flywheel and only part of a key on a engine you just rebuilt. This is an accident waiting to happen and also a big waste of time when it does. Good luck and I hope you rethink this move.
EM Iowa
07-01-2013 08:02:50
Its not a big crack, it's about 3/16 long.
sgtbull
07-01-2013 10:20:34
 Re: F-20 flywheel installation update in reply to EM Iowa, 07-01-2013 08:02:50
BAD PLAN! Complete failures start with small cracks. If you plan to NEVER use the tractor around anyone else, and NEVER sell it without disclosing the problem, so be it. But now that you've posted it on the internet, if anyone else EVER gets injured by it failing, you can bet that a well paid attorney will find this posting and you will lose everything you own. F-20 flywheels are readily avaiable and not expensive. I'd seriously reconsider that plan!
Phil Tibbetts
07-01-2013 08:23:33
Do you think it will get smaller? I've never seen a key I couldn't get out. Try drilling some small holes along the key and you should able work it out with a hammer and chisel.
EM Iowa
07-01-2013 10:28:58
 Re: F-20 flywheel installation update in reply to Phil Tibbetts, 07-01-2013 08:23:33
Alright, I'll try that.
Phil Tibbetts
07-01-2013 11:17:32
 Re: F-20 flywheel installation update in reply to EM Iowa, 07-01-2013 10:28:58
Use a drill just a little smaller than the width of the key and drill as close together as possible down to the shaft. It may help to put some good penetrating oil in the holes and let it set for a day. Good luck.
