TractorLinks.com
Show Parts for Model:
Re: Farmall H govenor
Janicholson
07-01-2013 05:05:18
Internal components in the gov. are probably worn. The link from the tube to the carb is tricky, and could be bent enough to jump out of the slot. If the carb to tube connect is for sure, going inside is a must. Jim
ellson
07-01-2013 06:30:36
 Re: Farmall H govenor in reply to Janicholson, 07-01-2013 05:05:18
I've been inside the governor and adjusted the stops and shortened the rod between governor and carb. If the governor spring was weak would it cause the engine to run too slow or too fast?
Janicholson
07-01-2013 10:50:37
 Re: Farmall H govenor in reply to ellson, 07-01-2013 06:30:36
Yes (too slow) but don't hardware stor the spring, use a Real IH part. Jim
