DK44H
Any guesses to how much a 460 farmall weighs that has a
standard hitch and the 6 bolt tin wheels on the front? Curious if
my trailer is heavy enough to haul it and the H I have. Thanks
460 GAS - 5263 POUNDS
460 DIESEL - 5483 POUNDS
Both tractors are tricycle, stamped steel wheels, TA, and IPTO.
If equipped with std. drawbar instead of fast hitch, the tractors would weigh a few pounds less.
Fluid in tires, added front and /or rear weights would add a lot of weight.
Stamped steel wheels meant front wheels. The rear wheels for this weight would be the standard cast rear wheels .
