Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall 450 rear diff fluid
06-29-2013 05:59:51
Loosen the drain plug under the PTO shaft, until you get a fluid to leak out. If it is water, keep draining it until you get oil type fluid. If it is a tan or milky color, either drain it all out, or let it sit a couple of days so that the water will separate from the oil. Then drain out the water. Then check the fluid level by removing the pipe plugs on the left side of the housing.
