TractorLinks.com
Show Parts for Model:
Re: Farmall 450 rear diff fluid
bermuda ken
06-27-2013 05:50:51
Factory fill is 80-90W gear lube.
IF you FLUSH the housing and have replaced EVERY oil seal, you can use Hytran oil instead.
You CAN NOT mix Hytran with 80-90W gear lube.
The tractor vet
06-27-2013 07:24:16
 Re: Farmall 450 rear diff fluid in reply to bermuda ken, 06-27-2013 05:50:51
BUT you forgot to say that along with the 80-90 you had to add some other juice to it and THAT IS no longer avail. Just like a posi rear end ya have to ADD some juice to the 80-90 . Case 310 G crawlers us a 80 90 MINERAL oil and guy get that confused with 80-90 and it screws up the steering brakes. I H switched from the 80-90 to the Hy Trans sometime back then because of T/A 's not working when cold.
D beatty
06-27-2013 06:23:38
If that tractor has a TA in it you have to use Hytrans oil. If it is TA delete you can use 80-90W gear oil. The oil in diff is also running through trans & TA.
