farmall 350 ID
Anonymous-0
can anyone help with my 350 farmall identification the serial number is 16305 SU it has single front tire, 42 inch rear tires and seems like axles are wider then average. i checked another site and all it said was it has a high altitude option and was built in 1968, can that year be correct thanks josh
Yes it could have long axles and 42"rubber.I would guess it was once used in a vegatable operation.It would be a '58,not '68...
16305 = year 1958 if its a 350. S = tractor came with a T/A and internal parts for a IPTO drive. U = the tractor came with higher compression pistons than standard, intended for higher elevation use. Long axles were a option. Standard rim size for a farmall was 38 inch.
Tractor was probably equipped with the non standard wheel and tires for a special use. Maybe what Georgeky mentioned.
