TractorLinks.com
Show Parts for Model:
Re: 400 axle housing leak
CNKS
06-26-2013 17:07:03
The gasket alone won't do you much good. You have to remove the wheel and the end piece which contains the seal. Of course replace the gasket also. Don't try to remove the wheel by yourself. I use an engine hoist (cherry picker) and remove the rim and tire, any weights and then the wheel. The 1st time I removed a wheel and tire the hoist tipped over, luckily I was on the opposite side. IF you mean the gasket between the tractor and the housing -- yes people have done that.
This post was edited by CNKS at 17:08:04 06/26/13.
Fudd@work
06-26-2013 17:51:24
 Re: 400 axle housing leak in reply to CNKS, 06-26-2013 17:07:03
Yeah, it's not the one at the end of the housing by the wheel, it's the one next to the rearend.
rusted nuts
06-26-2013 17:58:40
 Re: 400 axle housing leak in reply to Fudd@work, 06-26-2013 17:51:24
I'd check it and make SURE all the bolts are tight for I did anything else.
