TractorLinks.com
Show Parts for Model:
Re: Bush Hog PTO shaft safety cover removal? Yes or No???
Janicholson
06-26-2013 15:46:45
I would clean off the accumulated grease and slide it back into position. I would then drill holes so I could wire it forward using that flange on the Joint as a way to keep the shield from sliding rearward. Replacing it is also reasonable if you can get the part. I have had my share of encounters ans the cover is a good thing. It isn't your safety intentions in question, it is that unexpected wrong things happen. Jim
Russ from MN
06-26-2013 21:18:56
 Re: Bush Hog PTO shaft safety cover removal? Yes or No??? in reply to Janicholson, 06-26-2013 15:46:45
Maybe I am doing it wrong, but I took the chain off and let the plastic cover spin, but if you grab it will stop. That way it does not wear out.
David G
06-27-2013 11:18:28
 Re: Bush Hog PTO shaft safety cover removal? Yes or No??? in reply to Russ from MN, 06-26-2013 21:18:56
You are doing it wrong, should not be spinning.
Don R of Mn
06-27-2013 12:39:08
 Re: Bush Hog PTO shaft safety cover removal? Yes or No??? in reply to David G, 06-27-2013 11:18:28
It should be spinning with the shaft but be free on the shaft so it will stop turning if you get into it.
Russ from MN
06-27-2013 20:25:08
 Re: Bush Hog PTO shaft safety cover removal? Yes or No??? in reply to Don R of Mn, 06-27-2013 12:39:08
Thank you, that's what I thought!
