Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall Super A hydrualics getting hot very hot!
pete 23
06-26-2013 13:44:16
I never saw a Super A with anything but a touch control hydraulic system. You can add the aux valve as I assumed he did and took it all back off. Therefore, you are dealing with a closed center touch control system that when the rockshaft reached predetermined position, the spool in valve closed port to the orfice controlling the regulator valve and thus the fluid going through the orfice moves the regulator piston which in turn opens the bypass ball valve and system operates on low pressure.
chad from michigan
06-26-2013 17:27:02
 Re: Farmall Super A hydrualics getting hot very hot! in reply to pete 23, 06-26-2013 13:44:16
Do you think the screen pulled off and is stuck in there still causing problems? yes there was no screen and there was a piece of metal stuck in the orfice hole.
