TractorLinks.com
Show Parts for Model:
Re: Generator 12 or 6 volt
Jim Becker
06-25-2013 18:25:01
That generator number is correct for the original 6-volt cut-out based charging system. Now that you have used emery cloth on the cut-out contacts it will probably fail before long. You might be able to save it by recleaning the contacts with a point file then cleaning them with contact cleaner while holding them open. Otherwise plan on buying a new one. You have a fair chance if it is only a cut-out. If you used emory cloth on voltage regulator contacts, you might as well drop it in the trash now.
